Render time?
Render time?
I`m testing different render settings and comparing the results, but haven`t found a way to measure render time (like in some editing apps). Is there a way to do that in AS or if it is already there - where should I look for it?
						That depends on the codec, h-264 takes longer to compress then say QT animation codec, which is less compressed.
The time it takes to write to disk may play a bit as well, as in, if you render an uncompressed avi that can be several GB in size, writing time would normally be longer.
But, all in all, I use PNG, as it is fast to compress and usually small enough so the writing time does not play too much in your test!
Re: Render time?
Gilles,
this is a long shot but I just woke this thread, during some search, and would like to reply with Thank you, since I remember that your approach worked just fine.
Re: Render time?
Dang, We just got back in time, 4 years, almost to the day.
Glad I could help!
						Glad I could help!
