SWF file doesn't loop
gdub
Post by gdub »
Hi, I've searched the forums, and couldn't find an answer to this problem.
When I play back an animation that I've exported using the SWF format, It seems to play fine the first time, but when it plays again (for a second loop), the frame remains static, with none of the animation. Is there some sort of setting that will enable the animation to keep running? Thanks
gdub
Post by gdub »
As usual I found a solution AFTER I posted, by checking the extra SWF frame option in the project settings.
