Frame by frame test
Frame by frame test
Hello everyone.
A few days ago, after having a look at files donated by a kind user, I decided to do my own frame by frame workflow and I have been working on it since.
Here is the first scene I worked on. It is a scene with Tiana, a character from the Disney movie The princess and the Frog.
I have completed the first second of it, and here is how it looks so far.
http://www.mediafire.com/?a3agnnnp4guo789
This is my 4Th try at animating that first second of the scene, on this pass I got rid of the bones altogether, making it a full fledged frame by frame process.
So far I got down to around 20 minutes a frame, which is allot faster then the first pass which was over 45 minutes a frame.
The full scene should be around 8-10 seconds and I will post a new video every second.
- capricorn33
Re: Frame by frame test
Hey Gilles,
This is looking real solid!
cheers!
So you tried the combined bones / points approach first, then? What was it that made you decide to leave out the bones pass and go for clean point animation? Just curious to know about your findings here.GCharb wrote: This is my 4Th try at animating that first second of the scene, on this pass I got rid of the bones altogether, making it a full fledged frame by frame process.
cheers!
capricorn ( - just call me "cap")
children's tv pro, character animator
Hey Gilles, looks awesome.
Not that it doesn't look but it Is that finished?.. Just that you said 24fps on 2's with step interp, I wasnt sure if you intended to change the interp etc..
So to the layman(me) that is a new keyframe every 2 frames on step interp.... I guess that gives you an equivalent FBF from 12fps using a traditional drawing.
So I guess you need a decent drawing of the first frame and then push the points around.. scary.. sounds like a lot of work but the results speak for themselves.
--Sven
What *if* the Hokey cokey *is* what its all about?
Wonderfull work!!!
D.K
D.K
My store on Renderosity:
Although there is some wrong with my network
I can't open the download page
But read the reply, it seems good
I like the initiative to make animation
I like the others who think same as me
If you need help
if you do not mind making this animation with me
Please tell me
I'm glad to make it with you
My email address:244233256@qq.com
If you need help
Please tell me
Hello everyone!
capricorn, yes I tried using bones at first, but then decided to get rid of them since they we're a nuisance more then they we're helping.
I am taking allot from the movie, as this is an exercise in developing a work method, not one in making the most original animation, but I try to put some of my own along the way.
This said, might have been easier to make it from scratch.
Sven, it is not finished, only the first second, more to come.
Ulrik, DK, thanks.
244233256, maybe the service is blocked in China, I am emailing it to you!
Many thanks for your offer to help, but I see this as a personal exercise as I am developing a personal workflow with this!
I will post another one today.
Ulrik, DK, thanks.
I had to do the same. It's as if once you start delving into FBF and point animation bones become an anchor around your creativity and freedom of expression. I have actually developed my own skeleton structure for AS, designed to be more flexible than AS bones when fleshing out FBF ideas and motion in AS.capricorn, yes I tried using bones at first, but then decided to get rid of them since they we're a nuisance more then they we're helping.
D.K
- capricorn33
That sounds very interesting! Could you elaborate a little, please?DK wrote: ..../ I have actually developed my own skeleton structure for AS, designed to be more flexible than AS bones when fleshing out FBF ideas and motion in AS. /....
I'm curious.
cheers!
Please I don't want to hijack GCharbs thread as his work in this thread is wonderfull.
My skeleton still uses AS bones but the way they are used are a little different. I don't use bones to animate a character, only to plan out the motion I want to use. The skeleton is based on lines of movement but it is very flexible at shoulders and hips where the bones can be translated along the X axis if needed for walks etc. The head is a traditional split quarter view that uses switch layer interpolation for smoothness. I find the skeleton is non binding when used as a motion proxy to rotoscope a FBF character in AS.
http://www.polliefillers.com.au/forum/skelboybackup.swf
http://www.polliefillers.com.au/forum/run.swf
Cheers
D.K
Cheers
D.K
