To make good cartoony motions
aji
Post by aji »
to make good cartoony motion
export animation as image sequences(PNG with alpha for better results ,and
compositing in other softs)
Remove some inbetween images from sequence.
Then rename the image sequence in correct order
then import to composting soft.
Is this idea is okay...please post your coments
aji
ps:sure we can also create better results in Timeline...
SvenFoster
Post by SvenFoster »
Can you not just reduce the frame rate?
--Sven
What *if* the Hokey cokey *is* what its all about?
Mikdog
Post by Mikdog »
Hmm...not so sure this is an effective workflow. You could perhaps remove some frames (non-destructively) in your compositing software. Perhaps more accurate to do this all in the timeline though, with STEP keyframes?
