I imported a image and I put bones, I got that effect when I manipulate bones.
http://imagebin.org/161640
Thanks
Rigging problem
Rigging problem
ASP 7.1
I'm going to assume you imported an image and traced it to create a vector shape? If it's still a bitmap, then I dunno.
If it's a vector, then your bone influences aren't covering the points of the vector shapes well enough. Either separate the two shapes on different layers and bind the bones to the respective layers, or use the bind to points feature of the individual bones. And be sure to check out and/or read the manual, since this is explained pretty well there.
ponysmasher
Perhaps a bit more context of what it is you're attempting to do. That small, I assume cropped, image doesn't really tell us what you're hoping to do. It's not necessary to trace, again depending on what it is you're trying to do, but after tracing it's not necessary to keep the original around anymore.
There is any number of possible things youcould be attempting to do, which would explain or present a solution to you, based on your needs.
- funksmaname
- funksmaname
