Help Needed For Lip-Syncing (Bug on Layers)
systemcat
Post by systemcat »
I'm working with Anime Studio Debut 6.
I've been able to do this before but some thing is failing in it now.
Load two music files.
Load video file. Size video to screen.
Place one mouth on one character,
A different mouth on the other.
Set one mouth to sync with audio file one. The second mouth with audio file two. (Note both mouths have been placed where they should be on the characters and their properties haven't been changed).
...Mouth two for the second to be played sound file, is gaping open until needed, and as should shuts after the file is played. ..It shouldn't be gaping open!
It's not just that mouth I want to use, it's all of them! Tons of trouble shooting has gone into figuring out fixing this.
Help :(
You know you can just add any switch key by hand? Add the closed mouth in the end by yourself.
systemcat
Post by systemcat »
No no the mouth stays wide open before the audio file begins to play. After the file has been played the mouth is closed as it should be.
Applies just the same: after you did automatic lip sync, go into the timeline and add/erase switch layer keys as you need them.
