Anime debut 7~ needs random help~
Thewolfmuse
Post by Thewolfmuse »
ok i have a few questions and i dont even know where to start or what its called only examples soooo follow real closely...
on my characters after i put the bones on and try to move the characters arm- like the side of the head moves and the body or just something dose ALONG with the arm.
when i up load a character (like liz) this doesn't happen.
tried solutions~
weakening the bone strength- dose and doesn't help. it DOES help...... but it still makes other things move.
offset bones(i think its called? where the arm isnt attached to the body and i put bones where i put the arm at away from the body)- but that still doesn't help much.
are those the only 2 ways?
i mean i want it to completely not move any other part of the body when i just try to move the limb.
This is just a first of my many questions. im not gonna post them all at once but i will be using this post repeatedly when i have more questions that will pop up. but please help? and thank you if you can.
jonbo
Post by jonbo »
One of the quickest ways to get an answer is to upload your file to a file sharing site like mediafire which is free. We can then see how it's constructed and will be better able to find the solution. One thing I can think of off hand is maybe your bone hierarchy is wrong. Click on the bone layer and choose the re-parent tool. There will be red arrows showing the parent/child relationship on the bones. Make sure the arm bone isn't parented to the other arm or something like that.
Thewolfmuse
http://www.mediafire.com/?8c7ufk24khhmqwg
this was the first time i tried to make my own character... i realize there are some bones that arnt necessary like for the hair,....or are they?
http://www.mediafire.com/?537nrajoxn6bvi3
theres one im on right now trying to b more simple.
note that, im fairly COMPLETELY new to this program and even skeleton type programs in general, i do still art like on gimp so im just learning this stuff, but iv had the program sense december (xmas present) and i have been trying to figure things out on my own looking at some youtube vids. however i kept getting stuck. and i dont know the terms or names for things so i cant look them up directly. THEN i found this site just now. so here are the files (thanks for telling me the site, i didnt know it existed.) i hope i did it right.
jonbo
Post by jonbo »
I looked at your file and it appears to be a binding problem. Try using the bind points tool instead. You will have to add a few more points( like at the elbow and knee) to get them to bend right. Bind the upper bone to the points from the shoulder to the elbow and the lower bone to points from the elbow to wrist on the arm layer. Bind the hand points to the hand bone. You can do the same to the other layers. I won't chide you about your rigg, my first ones were lousy. See if this helps you. I like your character, reminds of a teacher I had once.
Thewolfmuse
how do i bind points?
jonbo
Post by jonbo »
select the arm layer for example, then select the upper bone. over in the tool palet you should see the bind points tool in the bone tool palet, select it. use the lasso to select the points you want to bind, and press the bind button at the top or the spacebar. the points selected should now be bound to the upper bone.
Thewolfmuse
kk ill try it out. thanks for helping, ill keep you posted on how its working out or if im doing somthing wrong or if i have more questions. lol but thanks
jonbo
Post by jonbo »
ur welcome. if you look at the Liz character like the torso layer, as you select each bone in the torso, you'll see how they bound the points. it will give you an idea on how best to place and bind your bones. good luck :)
sbtamu
Post by sbtamu »
In the help section in you AS program there is a help section and in that PDF there is a tutorial on binding, I think its page 207.
Sorry for bad animation
neeters_guy
Post by neeters_guy »
jonbo wrote:select the arm layer for example, then select the upper bone. ...
Also, while using the bind points tool, you can hold down the alt key and select a different bone if you need to.
Hey, great advice there, Jonbo. That's exactly what I would've recommended. :)
jonbo
Post by jonbo »
Thx neeters. I do what I can :)
Thewolfmuse
haha thank you you all. so far its working out great and just what i needed!
XD only thing is, i have to get use to it. but im sure more practice should do the trick :)
sbtamu
Post by sbtamu »
A lot of people make their character's parts afar from each other and use regional binding (I think that is what its called) and then bring them to the body on frame 1. I personally never liked that idea. I like to draw my characters with all parts right in the middle of the screen and then bind the points manually.
You are right though, It does take some practice learning to bind the points. In fact, IMO, it is one of the most important parts of the software that you should learn 1st.
Thewolfmuse
IMO?
and yeah i DID do it all in the middle, then i came upon this problem im practicing with b4 i knew what to do. so then i had spread them out and i went from there haha.
now, this program seems familiar to adobe illustrator(is it? cept animated....)...so i kinda know a little bit of how to do things, but there is no color picker is there? (the little eye drop thingy) like if you already have a color and you need the color again? or is there?
and also i need to learn how to shade and what not.
sbtamu
Post by sbtamu »
IMO=in my opinion
Yes, the eyedropper is the picker. If you want to change anything about a shape be it color, shades, gradients, you must 1st select the select shape tool then click on the shape then you can change 'stuff' for the shape.
