HUGE rendering problem!! I have about 30 hours to solve!
CrAzY Dan
Post by CrAzY Dan »
I have made a 3:29 minute animation and i put all of the seperate frames into windows movie maker. When i try to save the file as one whole movie file. It says that it is going to take 22,000 HOURS!!! What's going on?
Can anyone help?
Thanx.
CrAzY Dan :wink:
(i have about 30 hours to get the help i need :cry: )
15 year old Anime Studio user...
27/12/06: Im back and ready to get creating again!!
Rai López
Post by Rai López »
:shock: WOW :shock: ...So much time only for render 3 minutes of video from static images, yes ...What is the size of the images (frames) and what the resolution that you are exporting? Which Codec are you using? Have you a 486 PC? :roll:
Rai López
Post by Rai López »
I've open Movie Maker and I have seen that you can add effects now :shock: ...are you using some of that effects, aren't you? Which, WHICH??
CrAzY Dan
Post by CrAzY Dan »
the size is 720 x 486 and i don't know what else you are talking about! I'm only 13.
Rai López
Post by Rai López »
Well... SORRY! Seems that the resolution would must not be the problem... But you must tell me at least if you are using some of those effects or if you only have put your images and then go to save movie file; What computer do you have (only the processor velocity, PLEASE!)
CrAzY Dan
Post by CrAzY Dan »
I'm not using effects. I'm only putting my sounds and animation in and saving it. Processor velocity??
Rasheed
Post by Rasheed »
This isn't really a Moho question, try to seek help here:
http://www.windowsmoviemakers.net/Forums/
Personally I think Windows Movie Maker 2 is too restrictive. IIRC only the proprietary WMV9 and DV-AVI as output formats. And DV-AVI takes 200 Mb per minute of video (in your case about 700 Mb).
I hope you get help soon!
nobudget
Post by nobudget »
I have no experience with WMM but I'll try to give some help here...
-Are the frames created in Moho? Why not export as .avi in Moho?
- If they are seperate Moho scenes, export those as .avi and combine those in WMM.
- Many video apps set a single frame to a longer duration, so not 1 frame but 5 seconds for instance. This will greatly increase rendering time.
- What output format do you select? DV avi or WMV?
- How many original frames do you have?
- Is the sound .wav or .mp3 or something else? .wav is usually the most responsive, but the filesize is bigger.
Anyway, you seem to be doing something wrong, unless you have a computer older than you are it can't be a processor problem...
"i don't know what else you are talking about! I'm only 13"
Age is not the excuse for everything you don't understand. They are kids with a lot of knowledge and adults with barely any knowledge at all. You do not have the technical knowledge yet, that's not an age limited factor, there's a lot I don't know at age 30 :wink: Silly kids with them computer thingies, at your age you should get outside, smoke cigarettes without your parents knowing about it and trying to get a girlfriend but not knowing what to do with her when you get one :twisted:
Good luck...with the video, not the cigarettes,
Reindert.
www.nobudgetvideo.com
cribble
Post by cribble »
nobudget wrote: Silly kids with them computer thingies, at your age you should get outside, smoke cigarettes without your parents knowing about it and trying to get a girlfriend but not knowing what to do with her when you get one :twisted:
You're a bad man..... bad, bad man!
I think the "In" thing at the moment is starting a family at 15..... and happy slapping.
--Scott
cribble.net
