start render in a seperate process
moorsel
Post by moorsel »
Would it be possible to create an option which allows you to specify that rendering should take place in a seperate process. When working with many (rather large) png files I run into memory issues when redering from inside AS. Using the command line to render works just fine. I suspect spawning the render job as an seperate proces work more convenient and could have te same result wrt to memory footprint.
Gr,
Frank
My youtube profile: http://nl.youtube.com/user/fvmoorsel
