Verticies counter?
kellz5460
Verticies counter?
Post by kellz5460 »
Is there somewhere I can find out how many verticies a particular shape has?
I'm looking at this in regards to interpolating switch layers and to my understanding- to make a smooth transition both switch layers need to have the same amount of verticies
Does anybody know?
Vagabond
Post by Vagabond »
I can't find the 7feet HowManyPoints script but the Lost Layer Tool has a point and shape counter included and does TONS more than just count.
viewtopic.php?t=16862
There is a version for AS6 and for AS7.
Good Luck!
kellz5460 wrote:...to make a smooth transition both switch layers need to have the same amount of verticies.
That's a little way short of the whole truth -- the two layers need to have the same vertices, just moved around.
The easiest and most successful way for interpolating switch layers is to just duplicate one layer, then drag the points around.
If you don't want to make lip synch, it would be better to use Blend Morph instead of multiple layers on a switch. It's far more flexible and keeps things clean.
kellz5460
Post by kellz5460 »
thanks.
maybe i'll just do motion tweens for what I'm doing then
