Switch layers and onion skins
Impact
Post by Impact »
Hey, I used to use anime studio 5 were you could create points and layers on frames other than 0. When making effects i would create the switch layer and than be able to do a frame by frame effect useing onion skins. Now that i can only draw on frame 0 it is more time consuming to do onion skins and I cant animate in the context of the scene ( for instance see the distance that water has to fall and animate the splash in the right spot in that scene. )
Is their any way to create points and layers in the middle of the animation, or a way to make this easyer?
neeters_guy
Post by neeters_guy »
Under Edit->Preferences, uncheck Enable drawing tools only on frame 0.
Impact
Post by Impact »
aaaah, thanks
