The possibilities of Zbrush with ASP7
AeroneousFog
Post by AeroneousFog »
Does anybody know if you can successfully import things from zbrush. I was looking at the things you can do with zbrush and it's amazing. Mabye this is too much to ask from a mainly 2d program. Any thoughts??
If zbrush exports to obj, you can import it as a quiet object in AS. Not much more than that.
jonbo
Post by jonbo »
yes you can import zbrush objects as obj. files. Or import into poser and rigg bones then import into AS if you have AS7 pro. I've done this so i know it works. Be careful to keep the poly count under 100k, cause AS can't handle high poly count and crashes frequently. ZBRUSH ROCKS!!!!
