Hello,
I have a problem with a loop (cycle). I've made a walking character with 16 frames. I made a copy of the keys on frame 1 and put them on frame 17. On 17 set the keys to cycle with a beginning on frame 2.
Now I have a loop, but the keys of frame 17 (copied from 1) got lost, instead it doubles frame 2. This error only appears between the first to the second repeat of the cycle, the later repeats are correct.
I made some tests with looping to 1 or 3, also with deleting 17 and looping to 1. There it doubles frame 1 of the cycle.
My project have a framerate of 25. My ASP is Version 6.0 Build 20090526p. Could this be a bug or am I doing something wrong?
Thanks for your help from Animark.
Problem with loop - missing and double frames
- Víctor Paredes
Version 6.0 has a bug in cycles. I recommend you to look for version 6.2.
http://anime.smithmicro.com/index_pro.php
here you can download the update.
Hi Selgin,
thanks for that Info. Now I have to consult the system admin of our school, because I don't have the rights to make an update, so I hope I will get it the next days and not the next weeks
my blog: www.animationsfilm.de
