change Switch layers w/keystroke?
jdjd
Post by jdjd »
Hello gang!
is there an easy way to change switch layers/set switch layer keys with a keystroke?
I found an older script that seems to be pc only and I b Mac.
It would do the job dandy if I can get just get it to work.
Mac 10.6.3 Anime Studio Pro 7
thanks!!!!
jd
I suppose the script you have is too old for version 7. As far as I know, there is no difference between the scripts you use in win or mac.
Maybe you should publish the old topic of the script here and ask if someone could actualize it. I would help you, but I really don't know about scripting.
