looping a walk cycle (newbie)
cartoonkreator
Post by cartoonkreator »
hello everyone, I just got AS pro 6 and have been tinkering for the last week or so. I am still learning all the features and ins and outs.
Afer I build my character and create a walk cycle, when i want to repeat or loop that cycle what i have been doing is copying the keyframes from each individual bone layer and pasting it a few times and then repeating this process for each of the other layers. I am wondering if there is a quicker method or a way to copy/paste ALL the keyframes for all the layers at once. Or am i just going about this all wrong? I apreciate any help.
Thanks
When you do a walk cycle, use the cycle interpolation on the last key ... that's all.
Create a movement of lets say 12 frames. The last keyframe should be copied from the very first, so it matches exactly the first frame. Now right-click that key and set its interpolation to "cycle", write "12" into the text field in the popup and check "relative". That's it. Repeat for each separate timeline you use.
cartoonkreator
Thanks slowtiger, I will give this a try!
