Sticking SWFs together?
Jimi
Post by Jimi »
I've got several scenes of a cartoon as seperate moho projects and have exported them all to SWFs. How do I stick them together to form the final cartoon?
I want it to be in the SWF format, so I'm not using Adobe Premiere or Windows Movie Maker. I've read somewhere on this forum that it's possible to do this in Macromedia Flash but I tried and couldn't figure out how to do that. Could someone help me out, please?
Thanks
Nichod
Post by Nichod »
You just import the .swf into flash. Check the documentation. The flash manual should go through a good overview of this. You can also import the movie via video depending upon what version of flash you have.
Brian
Sometimes in order to accomplish something you need to not sleep.
Jimi
Post by Jimi »
Well I've tried what you said, I imported the two videos and then published it as one SWF, but there was a big loss of quality. I also tried importing them as SWFs, but half of the the objects in the animation completely disapear. :?
Nichod
Post by Nichod »
It could be the objects are disappearing because they are not supported via the swf format. The loss in quality is due to the specific settings you have and will require experimenting to get the level you are looking for.
Brian
