Deleting keyfrmes tool set request.
super8mm
Post by super8mm »
I found one script for deleting keyframes on current frame but it was an old script since it didn't account for deleting newer featured keyframes post v5.4.
There is a lack of tools for practical keyframe deletion.
-Deleting keyframes on current frame.
* with sublayers option
* with all layers option
-Deleting keyframes on all frames except current frame.
-Deleting keyframes in a frame range.
I haven't found anything else so once again I make a request, I would like to have these tools as I do many deletions when I test and edit actions.
neeters_guy
Post by neeters_guy »
Don't know if this is the same script you're referring to, but there's one by Touched to delete all keys in sublayers :
Tool to globally delete keyframes from cursor position
The script doesn't have all the options you listed, but it may be modded to suit your needs.
Rudiger
Post by Rudiger »
neeters_guy wrote:Don't know if this is the same script you're referring to, but there's one by Touched to delete all keys in sublayers :
I'm guessing that was the script that super8mm was referring to.
I have a function called get_layer_channels in my rt_utilities.lua script (supplied with my rt_key_tool scripts), so someone could use it as a guide for adding the missing channels. Also, not sure if Touched's script will have difficulties with the sequencer functionality. I know it caused me a lot of headaches.
