Export to flash (swf) outside issues
petel
Post by petel »
Hi All
OK, I've gone back thru all earlier postings on the subject of exporting to flash and now have a handle on most issues. We're animating for a web site banner and have a letter box work area. One element is needed to scroll thru frame but when I play the swf back I can see the letter box but also the element from the point that I created the layer, outside of the box. I appreciate that I can't use masks etc. but only want to see objects when they're within the work area. Any help gratefully appreciated
Pete
You definitely need Flash to optimize any SWF for usage in a website. AS doesn't have the controls for that. Only in Flash you will be able to embed links inside the SWF - and that's the main part of any banner.
petel
Post by petel »
Blast, I thought as much but very much appreciate the reply. Thank you Pete
You could try Kool Moves -- might give you enough functionality (eg, buttons) without having to shell out big bucks...
chucky
Post by chucky »
Or swish.
