I'm outputting a project in HD and getting some small white rendering artifacts- white dots and small white lines. Is this common, and/or does ASPro 7.1 fix it? The project has a lot of large bitmaps, but the artifacts are occurring over vector objects.
An y ideas?
ASPro 6 - HD Rendering artifacts
JohnArtbox
JohnArtbox
- Víctor Paredes
I'm not sure, but I think that problem is because you painted a shape without selecting all the necessary points.PARKER wrote:i think have had those white lines over my vector shapes as well, what i do to solve it is to delete the shape and then create the shape again.
This is common when one point of the future shape is out of the screen. For some reason AS assumes that the selected points cover a shape even when you don't select that out of the screen point.
