Script: Weld all points within radius.
Nichod
Post by Nichod »
Perhaps this function exists, or this is a script somewhere that does this. But occasionally I'm having problems with an imported file that I want to fill and it won't fill properly because of some obscure point that wasn't connected. Would be nice to have a function where we could select all and then use the tool and it would weld all points together by proximity.
Brian
Sometimes in order to accomplish something you need to not sleep.
myles
Post by myles »
Brian,
have a look at Scripts; Other; Auto Weld. Hopefully it should do just what you're after (although I think you may have to edit the script to change the default proximity radius).
Regards, Myles.
-- Groucho Marx
Nichod
Post by Nichod »
Yeah I discovered this :D a bit after posting this. Would be nice to have the script edited to have a box to control the distance of the weld. Would give it more uses. Need to play with scripting at some point.
