transparent fills in Anime Studio 7?
- Datawraith
Does Anime Studio 7 support transparent fills? I'd like to be able to do my glass effect.
A device that makes bad weather. . . interesting :/
- Víctor Paredes
Yes, it supports.
PD: What technically doesn't support is gradients and texture fills with transparency, but there are tricks to work with them.
- Datawraith
so now it supports gradients and textures with transparency? sweet!selgin wrote:Yes, it supports.
Also can it do alpha rendering.
- Víctor Paredes
No, sorry, I didn't say that (or at least I didn't want to). AS still having a problem with gradients transparency. Transparency in gradients exists and can be modified, but instead of showing you the objects behind your shapes, as you would hope, it shows the original color of your shape.Datawraith wrote:so now it supports gradients and textures with transparency? sweet!
It's old and not nice. I hope they solved it some day.
- Datawraith
what's different about 7 compared to 6?selgin wrote:No, sorry, I didn't say that (or at least I didn't want to). AS still having a problem with gradients transparency. Transparency in gradients exists and can be modified, but instead of showing you the objects behind your shapes, as you would hope, it shows the original color of your shape.Datawraith wrote:so now it supports gradients and textures with transparency? sweet!
- Víctor Paredes
On this topic I think there is no difference.Datawraith wrote:what's different about 7 compared to 6?
Re: transparent fills in Anime Studio 7?
Every graphic software ever supports transparent fills. You just don't fill the object. Bingo, it's transparent.Datawraith wrote:Does Anime Studio 7 support transparent fills? I'd like to be able to do my glass effect.
~Danimal
