I'm making a red/blue stereo animation.
Is there a way to specify a layer to be immune from stereo rendering?
Like a background layer.
Thanks.
Make layer immune to stereo rendering
Your not going to like my answer. You will need AS pro and Photoshop or Gimp.
Do a 2 pass render. On the first pass render out the red/blue animation. Then bring the video back in to AS with stereo off then render a second time.
Normally I would be telling you to render out as Quicktime png millions of colors+ but the stereo removes the alpha channel when rendering. So you need to render out to png pictures and manually use the magic wand tool to remove the black background in each frame then bring them back with the import image sequence script.
If anyone got a better way, please tell.
Dale
Dale
- funksmaname
