Anime Studio Converts Corrupt Avi files
arrionshadow
Post by arrionshadow »
I have a 5 minute animation I did but I can't seem to get it to Export to an Avi each file says its corrupt anyone know what the problem can be because it takes me about two hours to render and this is the third time ive sat around for 2 hours rendering a file that wont work
sbtamu
Post by sbtamu »
Are you saying you can render it but the file is corrupt when you try and play it?
If this is the case, try importing the AVI into VirtualDub and usually it will correct the error and then you can save it as a different name. I have done this a few times and it has worked.
Sorry for bad animation
arrionshadow
When I tried Virtual Dub it said
* Index Not found or damaged reconstructing file scan
*AVI:Invalid chunk at 2056
*Keyframe flag reconstruction was not specifieed in open options and the video stream is not known keyframe-only type. Seeking in the video stream maybe be extremely slow
(When playing back on VirtualDub I can see the Image but theres no audio and only 1 minute and 30 seconds of the clip plays out of the 5 minutes and 20 seconds)
I'm not sure what all that means so let me see if i can describe my problem better
When exporting to a SWF file My Eyes and Hair is completely gone
When Exporting Keyframe to avi from frame 0-500 I get a perfect AVI
If I export from 500-1000 I get no Audio
And If i try to export the whole video I get a Corrupt Avi File
If I cancel the video before it has converted i get My image with the entire Audio File but no Movement of the eyes and Lips
My Video is Fairly simple the only Movement and keyframes are The Eyes and Lips everything else is just Stillframe png Files
When trying other settings Such as Compressed settings I get a Very horrible quality video with distorted colors or a grainy picture
All I want to do is export to an AVI file, So far i've exported around 8 times each time taking me two hours to render, my Computer specs are an I7Processor with 9gb of ddr3 ram so I shouldn't be having any problems, Im not sure what to do i spent alot of time working on just the eyes its starting to really frustrate me, hopefully someone will be able to help me out. :P
