Combine the Shape and Layer manipulation tools
ErikAtMapache
Post by ErikAtMapache »
Combine the Transform, Resize, and Rotate tools into one tool (like Photoshop, CorelDraw,etc.). Drag while the mouse is inside the square to move, drag edge box to resize, drag rotate handle to rotate. Having separate controls is really a lot of useless button manipulation, and this change would significantly speed up work.
meltedtoons
Post by meltedtoons »
you can go to the Script section of the forum and request this, but the other options will appear at the top of the tool bar, if you know what i mean
Have you installed the fazek's tools?
If not, I really recommend you to do that. Check on scripts section.
ErikAtMapache
I appreciate your replies, I'll check it out (although it's always desirable to have things work "out of the box" since you avoid things like missing scripts, etc.).
