2 Audio Layer Limitations... but I want more!
DALinProgress
Post by DALinProgress »
I would like to add more audio to my animation, very basic stuff, but Debut only allows you to have 2 audio layers. My animation is quite lengthy compared to the amount of audio I need but I don't want to have 20 or 30 seconds of silence between sections when audio is needed as this will make audio file unnecessarily big plus make it impossible to move only part of the audio in the sequencer.
Is there an easy technique to record and add audio to an animation to circumvent this limitation? I would love to be able to have multiple layers so that audio can be moved in small chunks when needed. Does Pro have this limitation?? Thanks in advance for any help.
Pro haven't any audio or video limitation.
I always recommend pro, but it's obviously your decision.
Meanwhile, you can always mix audios on another software (like audiacity, for example) and then import the mixed wavs to ASD.
DALinProgress
Thanks for the response. I figured they removed that limitation... it's a pretty major handicap when trying to tell a story.
