switch layer
tiannaidan
switch layer
Post by tiannaidan »
In a tutorial I saw about lip syncing it showed in the layer options a "mouth switch" layer. I have pro 6 and I only have switch layer as an option in the drop down menu not mouth switch. Is there a difference?
The difference is that you put layers with mouth positions into the switch layer.
sbtamu
Post by sbtamu »
That mouth layer from that tutorial was renamed "mouth" layer by the animator. They made a switch layer then added the mouth shapes to sub layers and renamed it Mouth.
That is if you are doing tutorial 5.1.
Sorry for bad animation
tiannaidan
switch layer
That's kind of what I figured but it doesn't hurt to check. Thanks yall
