Saving a script in the right format
F.M.
Post by F.M. »
I am trying to modify the BoneAudioWiggle script to change stroke colors, but I can't save it in the right format, I'm using the Mac's Textedit and I don't see any options for saving in the Unix format, any thoughts on the subject would be appreciated!
"and then Man created god!"
I'm not using a mac, but through previous cross browser problems it seems that Mac's don't add a file extension by default... try explicitly naming the file "whateveryouwannacallit.lua" and hopefully it will work??
D.
Can you describe what you mean "can't save the right format"? What exactly isn't working? Do you get errors when using the script? Format shouldn't matter. It's just plain text. Make sure it has the .lua extension. Be sure that "display file extension" is turned on. Make sure you are saving as "plain text" and not RTF. I think text edit defaults to RTF.
I do scripting on both Mac and PC. I use a free open source text editor called "jEdit" that works the same on both platforms without any trouble. This program is great because it has syntax highlighting for lua.
F.M.
Post by F.M. »
Vern, I used J edit as you suggested, saving with it worked, this is what happened next(my first attempt at scripting) I put the script in the menu folder, then launched AS and the lua console gave this message
...plications/Anime Studio Pro 7/scripts/menu/Sound/LM_strokecolorsound.lua:39: '<eof>' expected near 'end
The script doen't appear in the pull down menu. This is what the script looks like. (don't laugh now!) :lol:
-- Provide Moho with the name of this script object
ScriptName = "LM_StrokeColorSound"
LM_LM_StrokeColorSound = {}
LM_LM_StrokeColorSound.BASE_STR = 2530
function LM_LM_StrokeColorSound:Name()
	return "LM_StrokeColorSound"
end
functionLM_StrokeColorSound:Version()
	return "6.0"
end
function LM_StrokeColorSound:Description()
	return MOHO.Localize("/Scripts/Menu/StrokeColorSound/Description=Uses a sound file to control a stroke's color.")
end
function LM_StrokeColorSound:Creator()
	return "Smith Micro Software, Inc."
end
function LM_StrokeColorSound:UILabel()
	return(MOHO.Localize("/Scripts/Menu/StrokeColor/StrokeColor/AudioWiggle=StrokeColor Audio Wiggle..."))
end
-- Recurring values
 LM_StrokeColorSound.audioLayer = 0
 LM_StrokeColorSound.magnitude = 255
 LM_StrokeColorSound.stepSize = 2
 stroke sound dialog
local  LM_StrokeColorSoundDialog = {}
function  LM_StrokeColorSoundDialog:new(moho)
	local d = LM.GUI.SimpleDialog(MOHO.Localize("/Scripts/Menu/StrokeColorSound/Title=StrokeColorSound Audio Wiggle"), LM_StrokeColorSoundDialog)
	local l = d:GetLayout()
	d.moho = moho
	      l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Menu/StrokeColorSound/SelectAudioLayer=Select audio layer:")), LM.GUI.ALIGN_LEFT)
	d.menu = LM.GUI.Menu(MOHO.Localize("/Scripts/Menu/StrokeColorSound/SelectAudioLayer=Select audio layer:"))
	for i = 0, moho:CountAudioLayers() - 1 do
		local audioLayer = moho:GetAudioLayer(i)
		d.menu:AddItem(audioLayer:Name(), 0, MOHO.MSG_BASE + i)
	end
	d.menu:SetChecked(MOHO.MSG_BASE, true)
	d.popup = LM.GUI.PopupMenu(256, true)
	d.popup:SetMenu(d.menu)
	l:AddChild(d.popup)
	l:PushH(LM.GUI.ALIGN_CENTER)
		l:PushV()
			l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Menu/StrokeColorSound/MaxAngle=Max angle")), LM.GUI.ALIGN_LEFT)
			l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Menu/StrokeColorSound/FrameStep=Frame step")), LM.GUI.ALIGN_LEFT)
		l:Pop()
		l:PushV()
			d.magnitude = LM.GUI.TextControl(0, "0.0000", 0, LM.GUI.FIELD_FLOAT)
			l:AddChild(d.magnitude)
			d.stepSize = LM.GUI.TextControl(0, "0.0000", 0, LM.GUI.FIELD_UINT)
			l:AddChild(d.stepSize)
		l:Pop()
	l:Pop()
	return d
end
function LM_function LM_StrokeColorSoundDialog:UpdateWidgets()
	self.menu:SetChecked(MOHO.MSG_BASE, true)
	self.magnitude:SetValue(LM_StrokeColorSound.magnitude)
	self.stepSize:SetValue(LM_StrokeColorSound.stepSize)
end
function LM_StrokeColorSoundDialog:OnValidate()
	local b = true
	if (not self:Validate(self.magnitude, -360, 360)) then
		b = false
	end
	if (not self:Validate(self.stepSize, 1, 1000)) then
		b = false
	end
	return b
end
function LM_StrokeColorSoundDialog:OnOK()
	LM_StrokeColorSound.audioLayer = self.menu:FirstChecked()
	LM_StrokeColorSound.magnitude = self.magnitude:FloatValue()
	LM_StrokeColorSound.stepSize = self.stepSize:FloatValue()
end
end
	local b = true
		b = false
	end
		b = false
	end
	return b
end
	LM_BoneSound.magnitude = self.magnitude:FloatValue()
end
-- The guts of this script
function LM_StrokeColorSound:IsEnabled(moho)
	if (moho:CountAudioStrokeColor() < 1) then
		return false
	end
	return true
end
function LM_StrokeColorSound:Run(moho)
	-- ask user for the angle offset magnitude
	local dlog = LM_LayerSoundDialog:new(moho)
	if (dlog:DoModal() == LM.GUI.MSG_CANCEL) then
		return
	end
	-- begin audio extraction
	local audioLayer = moho:GetAudioLayer(self.audioLayer)
	local audioDuration = audioLayer:LayerDuration() / moho.document:Fps()
	if (audioDuration <= 0) then
		return
	end
	moho.document:PrepUndo(moho.layer)
	moho.document:SetDirty()
	local frame = 1 - audioLayer:TotalTimingOffset()
	local layerTimingOffset = moho.layer:TotalTimingOffset()
	local layerFrame = frame + layerTimingOffset
	local baseOffset = moho.layer.fTranslation.value
	local newOffset = LM.Vector3:new_local()
	local audioTime = 0
	local frameDuration = self.stepSize / moho.document:Fps()
	while (audioTime < audioDuration) do
		local amp = audioLayer:GetAmplitude(audioTime, frameDuration)
		if (layerFrame > 0) then
			newOffset:Set(baseOffset)
			newOffset.y = newOffset.y + amp * self.magnitude
			moho.layer.fTranslation:SetValue(layerFrame, newOffset)
		end
		audioTime = audioTime + frameDuration
		frame = frame + self.stepSize
	end
end
The lua error you see is a result of an improper closing of a function or "if" structure. You have too many "ends" or one is in the "wrong" place. It could be the formatting got lost when you pasted your script here but it helps if you indent your code so you can see the structure.
I don't have time to find the error right now. Will try to look at it more closely later if I can.
TIP: if you paste script code in the forum use the Code button to wrap around it and it will keep the format intact for us to read it better.
F.M.
Post by F.M. »
I'm sure there will be multiple errors!
      return
   end\
Maybe the "end\" is the cause? :)
F.M.
Post by F.M. »
Genete, I will see if removing that, will allow the script to function.
Thanks for taking time to help.
F.M.
Post by F.M. »
I had no luck with that, It must be something more serious.
