When trying to enter a value in the line width field, Moho seems to be performing other actions. For example, if I type '1' it switches to translate layer, if I type '2' it switches to scale layer. It's as if Moho doesn't recognize I'm where I'm typing. We're I on a PC, it would make me suspect that num lock was on/off.
I haven't seen this behavior in any other entry fields though, just in the line width field.
Thanks.
Mac OSX 10.3.5, Moho 5 beta 3
Beta 3, OSX line width entry
I noticed the same issue and I'm sure LM will fix it. As a workaround, when I want a constant line width around a shape, I just select all points in the shape, and use the line width tool to adjust all the segments simultaneously.
Courtesy of: Your Friendly Neighbourhood Armaani
Independent Storyteller, Humourist, Absurdist, and All-’Round Nice Guy
http://armaankhan.blogspot.com
- Lost Marble
Thanks for the tips.
I don't have a wheelie mouse (I like my silky smooth Apple mouse), but my PowerMate does the trick - it's not just for scrubbing the timeline anymore. I hadn't thought to try it in the entry fields until you mentioned the mouse wheel.
Moho 5 is sure looking sweet. Keep up the good work.
- Lost Marble
