Hey Guys!
I have a problem with lipsync. I´m using the standar mouths that came with Moho and now anime studio. I´m using Spanish as the lannguage.
The problem is the mouths go too fast when I export the animation, but when I just prteview the lipsync inside AnimeStudio they go exactly at the speed I want them to.
I´m working on NTSC 30fps exporting on quicktime.
Any ideas?
Thanks in advance.
Cheers!
lipsync Problem HELP
lipsynk
Hi there.
I use papagayo... It works like this:
1- open Papagayo
2- Import the audio file
3- type the text on the text box
4- select a language (spanish is an option)
Then, you´ll see a graphic that you can manipulate...to synk properly.
Then, go to File- Export- "data file" and voila...
Open AS, import the .dat file made in PAPAGAYO, import the audio file on AS, import the mouth file. Once you have import the mouth set, select that layer, goto "...", seek for the last tag, and sync the mouth with the dat file, and this is it...
You can see a lot of examples on my youtube channel... "ricardosandilizano"...
SeeYou
1- open Papagayo
SeeYou
