Particle Effect Man
- fracturedray
Particle Effect Man
How I did this... http://www.youtube.com/watch?v=iwoqL5gbdCc
This is basically particle effects attached to bones but some extra things needed to be done to get it right.
I drew out the shape of a man and made him weirdly proportioned.
I opened the shape layer settings and turned on the noisy settings for the man's body as well as the particle effect shapes.
Then I started on the particle effects in the belly. I played around with shapes and particle effect animation settings until I found something I liked. I then used the tip selgin had for eliminating particle trails.
Tip: Each shape in the particles use “cycle” because I animated them fading out.
I duplicated the effects layer and placed them all over the body changing sizes/settings as needed.
Once done I did a short animation. I saw that the man's body looked ok but I wanted to just use the particle effects only.
So I duplicated all the effect layers and shorten the duplicate effect life down to 4 frames. This made the body shapes more obvious.
Here is the final file. http://www.mediafire.com/?yvtmuaiqba5zbt0
You are welcome to learn from it. Just be aware that it took 30 minutes to render 11 seconds.
Hi animation world.
- fracturedray
- fracturedray
