switch layer images don't export to swf
JohnArtbox
Post by JohnArtbox »
Hi
I'm working out a new workflow for a project and slowly getting different things into place. My current stumbling block is that on a test export of a switch layer (using image layers), the images didn't appear in the swf export. I've been through the manual and it doesn't list this as one of the export issues for flash.
Is it possible? Is there a setting I'm missing?
I'm currently using ASPro 6, although I'm happy to upgrade to 7 if that fixes the issue.
Imago
Post by Imago »
Swf don't support warped raster (PNG, BMP).
Be sure the layers don't been warped by bones but only rigged.
JohnArtbox
nope....no bones in the test file, just dropped the image layers onto a single switch layer.
Imago
Post by Imago »
In this case I don't know how to solve...
Re: switch layer images don't export to swf
JohnArtbox wrote:Hi
Double check the Flash export options:
http://www.lostmarble.com/moho/manual/i ... htips.html
ponysmasher
Post by ponysmasher »
I've never gotten that to work either. I've alway had to animate the visibility of the layers instead.
There are a lot of hoops to jump through to get the flash export to work properly but anything to avoid animating in flash...
For my project I only needed one image layer visible at a time in the entire document so I wrote a script that turned off the visibility for every image layer except the selected one, which was set to on.
JohnArtbox
I just reread the options and switch layers are not mentioned. Image layers are ok as long as they are not warped by a bone layer. Since a switch layer doesn't warp the images is this a bug?
Images bound to a bone work perfectly in a flash file, they just can't be distorted.
JohnArtbox
Tech Support comes through...first time I've ever used them :)
Even though there were no bones in the test scene, you still need to uncheck the warp using bones box on each of the image layers.
I've since added bones to the scene and used bind layer on the switch layer and it works perfectly.
Very cool...and thanks to John Csaky at Smith Micro.
ponysmasher
Aw man... That information could have saved me a lot of time a couple of months ago.
Thanks for taking the time to find that out though.
If you're not afraid of diving into code, you can open a copy of your AS file in a text editor and batch edit a setting like "warp with bones" all in one go. Of course this attribute has a different name:
parent_bone -1  is "don't warp"
parent_bone -3  is "warp"
parent_bone 0   is "bound to bone"
(can someone confirm this?)
