I have an animation that is pretty long and often found myself adjusting the project settings of the Start Frame and End Frame to watch one section play and tweak it.
I think it would be helpful if there was a "Work In Progress Loop Markers" next to the onionskin button that the user could use to loop the player without having to go to Project settings all the time or have to hit play/stop and move the active timeline frame back.
-ray
Temporary Loop Marks
- fracturedray
Hi animation world.
- fracturedray
- Víctor Paredes
Change ALT for Ctrl and you will have the needed loop without changing the project duration.jahnocli wrote:You can already do this. ALT-left click on the timeline to set the start, and ALT-right click to set the end. The animatiion will now loop between those two marks.
