I Just got Anime Studio Pro 7.
I'm doing the first tutorial and certain tools are not working as they're supposed to.
For instance, the Curvature Tool. I can select a point but it doesn't drag.
Same thing with the Line width tool.
Everything else in the tutorial worked as expected.
Thanks.
Some tools not working right in Intro Tutorial
- Víctor Paredes
that's weird. Have you tried with other files? Are you sure you are using well the tools?
If it definitively doesn't work, try re installing AS.
Are you holding down the left mouse button and dragging the mouse left and right?
Re: Some tools not working right in Intro Tutorial
Your phrasing makes me wonder if you are expecting those tools to move the point. The point doesn't move but dragging left and right changes the curvature or the line width.NealF wrote:I Just got Anime Studio Pro 7.
Barry
Aha! Barry. You hit it on the head.
I did think the line would move. Or, in the case of the point changing angle, I was expecting to see it change from a curve point to a corner point. As in bezier curves in other programs.
OK. Problem solved. Thanks all.
Now I'm looking forward to really learning the program.
