Get position of a point?
ponysmasher
Post by ponysmasher »
I'm probably missing something really obvious here but I've managed to get for example the x translation on frame 5 of a layer like this:
local layerVector = LM.Vector3:new_local()
layerVector=textGroup.fTranslation:GetValue(5)
print(layerVector.x)
But how would I get the position of a point?
I know for sure that this doesn't work:
numPoints=mesh:CountPoints()
	print(numPoints)
local vt = LM.Vector2:new_local()
	for i = 0, numPoints-1 do
	vt = mesh:Point(i).fPos:GetValue(0)
	print(vt.x)
	end
I get the first print and then an error. I'm guessing the problem is this syntax:
Rudiger
Re: Get position of a point?
Post by Rudiger »
ponysmasher wrote:I'm probably missing something really obvious here but I've managed to get for example the x translation on frame 5 of a layer like this:
	print(numPoints)
	print(vt.x)
	end
This section of the forum appears to be getting more active lately, which is awesome! There is still so much untapped potential in AS just waiting to be realized!
Anyway, try using fAnimPos instead of fPos. fPos is just the current poisition of the point, so doesn't have a GetValue method, whereas fAnimPos is the animantion channel you're probably looking for.
    mesh = moho:Mesh()
    for i = 0, mesh:CountPoints() - 1 do
        local v = LM.Vector2:new_local()
        v = mesh:Point(i).fPos
        print(v.x)
        print(v.y)
    end
or...
    mesh = moho:Mesh()
        v = mesh:Point(i).fAnimPos:GetValue(0)
        print(v.x)
        print(v.y)
    end
Rudiger is correct. fPos is direct access to the points position. fAnimPos you can get the value from a specific frame regardless of what frame you are on.
Generally I use fPos more because the code is simpler and you can CHANGE it and READ it much easier. fAnimPos must use..
fAnimPos:SetValue(frame, value)
to set the value and...
fAnimPos:GetValue(frame)
to get the value
fPos is easy, just "fPos = newPos" to change it. Of course that won't work if you want to change a position on a different frame.
I believe that fAnimPos is also needed to set a key frame... don't quote me... working from memory. :)
p.s. fAnimPos and fAnimAngle are very cool. I created a bone tool that would move and rotate bones only on frame 0 no matter what frame you were on. It was done ages ago for version 6 because of the sequencer. If a bone layer was slid BEHIND frame 0 of the document you couldn't reach frame 0 of that layer to move bones around.
ponysmasher
Yep, now it's working.
Thanks for the help! :D
