How do I fade image layer?
steve19
Post by steve19 »
I know how to animate layer visibility, but I want to fade in an image. When i adjust image layer opacity it doesn't create a keyframe for it!
I need help fading in/out an image layer. I am using a png image.
Imago
Post by Imago »
Double click on the layer, it opens the property window.
Search for "Opacity" option on first tab.
You can use it to modify the transparency of the layer, (100% on first frame, 0% on last, the image will fade to black) :wink:
*EDIT*
Sorry, I forget to say you have to tick the "Allow layer animation" option :roll:
And that effect will work only on video and image format when exported. SWF Don't support such image effects.
steve19
Post by steve19 »
Ahhhh. Right in front of my eyes! Thanks!
Post by 94253 »
Imago wrote:Sorry, I forget to say you have to tick the "Allow layer animation" option
THAT was what I had been missing... Thanks for adding this detail! I should have known better. ;)
Also note that image layer transparency doesn't show in the preview or workspace window. You must render to see it.
Lukas
Post by Lukas »
heyvern wrote:Also note that image layer transparency doesn't show in the preview or workspace window. You must render to see it.
I would love SmithMicro to fix this.
