Timeline Switch Layer Menu
Rai López
Post by Rai López »
This is not much important, cause there is many ways to do it (by Layer window or Switch tool), but I think that instead a keyframe interpolation menu (that is not necessary because Switch Layer Channel only supposts "Step" type, when you do right click in Timeline Switch Layer Blue Line, the menu could mostrate the sublayers list (AI,E,FV,MBP,i.e...) to can add directly in Timeline the Switch keyframe that you want and where you want quickly and easy, I've said that only for comodity, CIAO!
7feet
Post by 7feet »
I second the motion. I would use that, well, pretty much every day.
Rai López
Post by Rai López »
THANKS! ...Well, I don't know why, but I prefer work directly in Timeline, I found it more intuitive, suppose... The only problem that can be with this (I don't thought when I wrote the topic) could be if you have a LOT of sublayers and the way of Moho could show it... I think that is not a big problem, cause I never would have so many sublayers, but well, only for consider it... CIAO!
