Moderators: Víctor Paredes , Belgarath , slowtiger
Tagirijus
Posts: 87 Joined: Fri May 14, 2010 3:31 am
Post
by Tagirijus » Fri Jun 11, 2010 1:28 pm
Hi there,
I now got Anime Studio 7 Pro. I'm stlil learning the new features, but first I wanted to set up my setup like in 6. Now I recognized that ASP7's library is on my system-partition on which I do not have that much space anymore. Is there any way to change the standard library path? Best would be the path in the ASP7 installation folder.
Thanks for help.
Manu
GCharb
Posts: 2281 Joined: Sun Oct 09, 2005 6:31 pm
Post
by GCharb » Fri Jun 11, 2010 1:52 pm
There is a "Use old library" under the preferences, might do it!
G
Tagirijus
Post
by Tagirijus » Fri Jun 11, 2010 1:54 pm
Thanks for the reply and the tipp. Actually I already tested this checkbox; it seems to be just for the appearance, not for the intern datas / paths.
Imago
Posts: 698 Joined: Wed Dec 10, 2008 12:48 am
Post
by Imago » Sat Jun 12, 2010 8:54 am
I Have the same problem.
The ASP 7 Library as been put on "Public" folder of documents...
Very bad to manage it in that way!
Tagirijus
Post
by Tagirijus » Sat Jun 12, 2010 8:56 am
Luckily I am not alone with this "problem" / "dislike". I think this problem won't be solvable by a member, or? It seems to be hard coded.
ulrik
Posts: 1087 Joined: Thu Aug 11, 2005 2:32 pm
Post
by ulrik » Sat Jun 12, 2010 10:04 am
I don't know what os you run, I'm on mac and can change the paths by using "symbolic links" so I can place me library where ever I want and just make a link to the original place. I guess there is a similar way to handle it in windows or linux?
regards
Tagirijus
Post
by Tagirijus » Sat Jun 12, 2010 10:05 am
Thanks for the tip. I had this idea last night while I was sleeping ( no joke ), but forgot it till now. I am going to test it soon, hehe.
Tagirijus
Post
by Tagirijus » Sat Jun 12, 2010 10:35 am
Does not seem to work.
ulrik
Post
by ulrik » Sat Jun 12, 2010 10:39 am
Tagirijus wrote: Does not seem to work.
what os are you running?
Tagirijus
Post
by Tagirijus » Sat Jun 12, 2010 11:07 am
I'm running Windows XP Home.
ulrik
Post
by ulrik » Sat Jun 12, 2010 11:22 am
Tagirijus wrote: I'm running Windows XP Home.
I found this site about "junction link" as I understand it it's about linking a folder, maybe this is a solution for you, I don't know?
http://www.rekenwonder.com/linkmagic.htm
Tagirijus
Post
by Tagirijus » Sat Jun 12, 2010 11:24 am
Thanks for the tip. I will test it later and report the achievement.
Tagirijus
Post
by Tagirijus » Sat Jun 12, 2010 2:08 pm
This did work. Superb.
Thanks again for this tip!
ulrik
Post
by ulrik » Sat Jun 12, 2010 2:58 pm
Tagirijus wrote: This did work. Superb.
I'm glad I could help
