Import Image Sequence - sometimes
theotherguy
Post by theotherguy »
Hi all, I'm faced with a perplexing dilemma, sometimes when I go through Scripts > import image sequence, then select the 1st numbered file, sometimes it works, sometimes it doesn't. Does it matter where the number of the file is?
thanks
ErikAtMapache
Post by ErikAtMapache »
I had the same problem, then I noticed that the images didn't end with the number -- that is I named them img_001_all.png instead of img_001.png. I'ts always the dumb stuff that gets you.
theotherguy
Thanks, it will save me a ton of time, now I just have to rename my files . . :(
There's many free applications for renaming out there, for every platform. On Mac, I use "Renamer".
