I'm trying to do spotlights.
Loan
Post by Loan »
Everything is going well, I'd just like to know if it's possible to 'anchor' one end of the light to the ground. I've got a bone anchoring it to the light fixture, and the celling, but when I manipulate it, the light breaks off the floor.
Rai López
Post by Rai López »
Loan
Post by Loan »
Okay. When you turn a spotlight on and swing it around facing the ground, the light just doesn't 'break off' in midair, does it?
myles
Post by myles »
Make the part of the light that hits the ground controlled by a separate bone, or (possibly even better) animate the ground-hitting points directly after swinging it around using your bone setup.
Alternatively, try doing something with masking, and use the outline of where the light hits the ground as part of the mask. This just means you'd have to manually animate the mask rather than the points hitting the ground.
Regards, Myles.
-- Groucho Marx
