Moderators: Víctor Paredes , Belgarath , slowtiger
XFracture
Posts: 18 Joined: Thu May 20, 2010 5:46 pm
Post
by XFracture » Mon May 24, 2010 6:07 pm
I have an image in a scene of mine. I sheared it so it's on an angle and placed it over a tv I created. Now everytime I move the camera or even the parent layer the image shears with the layer/camera. How do I stop this from happening?
Posts: 6325 Joined: Thu Feb 16, 2006 9:53 am
Post
by slowtiger » Tue May 25, 2010 1:32 am
You can't. The shear is in 3 dimensions, so it always will look different every time you move the camera.
Trick: render 1 frame where the sheared image looks good, import this bitmap instead of the sheared one. All will be good.
Rhoel
Posts: 844 Joined: Thu Feb 24, 2005 11:09 pm
Post
by Rhoel » Tue May 25, 2010 3:29 am
If you use the Orbit button (key 9), you will see why you can't.
RHoel
XFracture
Post
by XFracture » Tue May 25, 2010 8:50 am
Aaaaaaah. I see now. Thanks for the tip slowtiger. I will have to remember that.
Mikdog
Posts: 1901 Joined: Tue Jul 05, 2005 7:51 am
Post
by Mikdog » Tue May 25, 2010 2:00 pm
Or you could go to project properties and uncheck enable 3D camera. But then your shear might not look the way you want it either. At least it won't move your shear when the camera moves.
Posts: 3174 Joined: Tue May 29, 2007 3:31 am
Post
by funksmaname » Tue May 25, 2010 7:19 pm
can you use the 'shear points' tool at the top instead of the shear layer tool? that way it won't actually turn it in 3D space?
Not been around in a while, greets Slow/Rhoel/Mikdog - hope all is good
Rhoel
Post
by Rhoel » Tue May 25, 2010 9:05 pm
funksmaname wrote: Not been around in a while.
Welcome back - I hope you brought a note from your mum
Post
by slowtiger » Wed May 26, 2010 1:13 am
funks: with vectors, yes. But he was asking for an image layer.
