PLEASE HELP ME!! PLEASEEEE =(
robymcfarlane
Post by robymcfarlane »
Hello everyone .. I just use anime studio 6 pro, and I have a difficulty .. I can not overlap images .. drawing on a level if I want to bring back an object over another, how can I do? please help me = (
Draw stuff on different levels. You could change the order of layers by dragging the layer tabs, even animate this changing order if they are in the same group/bone layer.
robymcfarlane
thank you .. in a tutorial that I saw on youtube, through the command "fill" drag behind the object. in this case had an ear that led him to turn around the face, but on the same layer "head" .. it's possible?
then, animating on different levels, if I change the same layer group (eg "open hand" closed hand ") it also changes between frames .. you can change layers in the animation or you must always keep the same?
(sorry for the post in the wrong section)
Rhoel
Post by Rhoel »
robymcfarlane wrote:(sorry for the post in the wrong section)
No problem - we move subjects around as they are more likely to be answered if they are in the correct topic area.
