Perspective trouble
sbtamu
Perspective trouble
Post by sbtamu »
I am having trouble with perspectives when I use image textures. I have a cabinet view of a building and the texture I use(brick wall) for the front is OK and I can scale it fine. But on the side wall the texture does not have any perspective. I used GIMP to add perspective to the texture but when I do this and import to AS I can see the alpha layer if I use tile(witch I need to scale the image). If I use "don't repeat" the bricks fit fine but i cant scale them down.
If you need snap shots of what I am talking about I will upload them.
thanks :D
Sorry for bad animation
If a texture in AS has to appear in perspective, you need to fill an undistorted shape first and then tilt the layer (rotate around x or y).
sbtamu
Post by sbtamu »
I have tried everything I can think of but the texture is acting like it's masked. I just can't seem to get the bricks to narrow as they reach the horizon. And if use gimp to add perspective to the texture I lose the ability to scale the texture.
1 is the closest as I can get but as you can see the brick sizes are all wrong.
2 and 3 are the right brick sizes but the perspective is wrong.
4 and 5 are tile and don't repeat.
Mikdog
Post by Mikdog »
I'd use just the PNG images imported directly.
Going with your '1' example, the front brick looks good. Then duplicate that, and duplicate it again. Put the two duplicates in a group/bone layer. Move the second duplicate over to the right so you have double the width of the wall in a group layer.
Move the group layer over to the right so that it looks like you have 3 wall panels all neatly lined up, just touching.
Set the origin of the group layer where the front wall and the first wall of the group layer touch.
Use the perspective tool to 'push' the group layer back around the x axis. It should rotate around the correct pivot. So you're really making a 3D-ish object.
sbtamu
Post by sbtamu »
Ok thanks, I'll try that
sbtamu
Post by sbtamu »
Never mind.
Debut doesn't have perspective tool.
I will buy Pro today.
