When i import ai file with gradient color,
yuzh652800
Post by yuzh652800 »
When i import ai file with gradient color into anime studio,the gradient color looks not work ,why?
anyone can tell me?thank you.
AI and AS use different ways to represent gradients, as well as AS and SWF. That's why you have to rebuild gradients in AS after importing from AI.
yuzh652800
it's so bad for most animators ,we often draw our characters in ai or flash,and drawing in as is not so convenient.
is there any plugins can collaborate this two software?[/quote]
Please do a search in this forum about imoporting AI into AS. We had this discussion for so often, I won't repeat it here.
Learn to draw in AS if you want to animate in AS, that's the best advice I can give.
AmigaMan
Post by AmigaMan »
I think that's good advice Slowtiger. I don't get these "I can't draw in AS" posts. I use a lot of drawing software and I don't find AS any more of a problem than any other vector package. Maybe I just use it more and am particularly familiar with it but I find it very easy to get what I want within AS and just couldn't be bothered with the hassle of drawing (especially in another vector package) and importing. :shock:
yuzh652800
i m a newcomer of AS,it might be well later
i search "imoporting AI into AS"and other related keywords,but no result return
@Slowtiger:is there any url about this topic? can you paste it here?
in AS ,when i fill objects in gradient,i can't see the gradient directly in the workspace,i must see it after render,it's not so convenient.
Search the FORUM. See that line of links at the top there? Including "Search"? With the phrase "import ai into as" I found 1687 matches.
yuzh652800 wrote:in AS ,when i fill objects in gradient,i can't see the gradient directly in the workspace,i must see it after render,it's not so convenient.
Yes, it's a bummer. But it's not a deal-breaker, usually, and it's not going to change anytime soon (probably), so you'll just have to suck it up like the rest of us...
bleep
Post by bleep »
I draw in inscake and import into anime studio. The result is much better tha AI!!! :shock:
yuzh652800
bleep wrote:I draw in inscake and import into anime studio. The result is much better tha AI!!! :shock:
what format do u save your inkscape file as? the default one is .svg,but how can we import a svg file into AS?
i try .eps ,but i seems not work yet .
yuzh652800
today i installed the 6.0 version (I used 5.5 before) and i found that i can see the gradient color in the workspace directly,that's so great.
i think i can draw in AS later and never need import ai file.
wena
Post by wena »
I would also like to know what format you are saving from inkscape to!!
Wena[/i]
wena
Post by wena »
I would also like to know what format you are saving from Ink skap to!!
Wena[/i]
wena
Post by wena »
But yuzh652800 tell us what format do you save files from in inkscape?
I am not the only one who has asked this question
