head turn
jose1984alberto
head turn
Post by jose1984alberto »
here is my aproach on a head turn using traditional animation techneque
the vid http://www.youtube.com/watch?v=4F4SxrygHWA
the file http://www.mediafire.com/?zjctiznrmz2
GCharb
Post by GCharb »
Hello jose
Not a bad start, but it is a bit stiff, I suggest you put a bit of anticipation and some arc motion into it.
Here is a head turn I made a bit ago that uses both
Head turn 440 kb
Or this one
Homer.mov 565 kb
G
jose1984alberto
GCharb wrote:Hello jose
oh, absolutly... the neet thing about it is the inbetween "swoosh", as you can see in the file...
i think your homer head turn would look perfect if you add that effect...
GCharb
Post by GCharb »
jose1984alberto wrote:i think your homer head turn would look perfect if you add that effect...
True, a bit of motion blur would help! :)
G
lwaxana
Post by lwaxana »
Nice use of the swoosh technique. :D I keep seeing that technique in the Animator's Survival Kit. It's cool to actually see it in action. Makes for a nice punchy movement.
jose1984alberto
thanks for the coments, i snached the technique form an animation webinar, this is the link http://www.animationmentor.com/webinar/ ... binar.html, and its not "swoosh" efect... its "smear"... and as Eric Goldberg says ther, you really have to know when you can use it, you gotta be really smart about it cus you can end up with an unwanted effect in thw whole animation, he puts "Jonny Bravo" from cartoon network as an example of overused smear effect
lwaxana
Post by lwaxana »
Oops! I didn't realize that this was called smear. ;D Thanks for clarifying that. The Williams book also calls this technique "long-headed inbetweens" or elongated inbetweens. Earlier today I came across this example that uses a ton of smear: http://johnkstuff.blogspot.com/2009/07/ ... poses.html Interesting stuff!
Thanks for sharing that Eric Goldberg interview link. Just watched part one and looking forward to watching the rest!
scilencer
Post by scilencer »
the manufacturer work is great hear, thanks for sharing :shock:
