Shape only half filled
macnavi
Post by macnavi »
This is the second time I encounter this problem and I can't figure out why it happens or how to solve it.
I have created one shape with the Add Point tool. When I want to fill it, it only fills half of the shape for no reason. Strange, because I made it in one go, as one shape. And it's clear that the shape is closed, otherwise there wouldn't even be possible to fill it.
Anyone any idea how to solve this?
Click here for the project file (one vector layer)
The opening at the bottom is hidden on purpose.
sbtamu
Post by sbtamu »
try zooming in real close till u get the whole image to get the checker pattern then hit create. happens to me alot also.
Sorry for bad animation
macnavi
Post by macnavi »
Thanks for the answer. No, that doesn't work. The moment I click inside the empty space with the Select Shape tool, the shape gets deselected.
sbtamu
Post by sbtamu »
Try messing with the lines that end know where. The problem is prolly there. Pull each point back and make sure no lines are overlaping, once u get the shape made pull them back to where u want.
Also, Did u hide the lines ontop or are all the points not all connected?
macnavi
Post by macnavi »
Just tried that, but it really is one shape. You can see that it fills up very strange, as the fill at the left doesn't start where there is a vector point, but between two vector points. If you copy-paste this in a new document, it does the same.
Did you import this shape? If you did, the likelihood is that there are some vector points on top of each other. I'm afraid there is nothing for it but to systematically tweak each point, to see if any other points are hiding underneath. Bummer.
If that doesn't work, you might need to break one of the lines, reconnect it and re-fill. Bummer again...
sbtamu
Post by sbtamu »
I think the problem is here, try removing ponts
It's exactly the same problem described and solved here:
viewtopic.php?p=90162
macnavi
Post by macnavi »
That was it, Selgin. Deleting the fill, select all points and fill again. It was most likely filled with not all points selected.
Somehow, I knew you would come up with the answer!
base_ball
Post by base_ball »
I has the same prob. :D
help please! 8)
macnavi
Post by macnavi »
Well, the answer has been given. Can't you solve it now?
Atalklyng_crow
Post by Atalklyng_crow »
agreed! :wink:
sbtamu
Post by sbtamu »
when this happened to me it was cause a point was on top of another in a shape similar to yours. I had to actually remove points till i found the problem.
Anyways, CGS on problem solved :D
