Transparent hole when rendering simple shape
Why does 94253 make all his threads polls?
He is bored.
1
100%
He is a funny guy.
0
No votes
Total votes: 1
Post by 94253 »
My JPEG and *.anme files are at http://sto.gfcmedia.net/cabinet
When I draw the shape it appears solid black as it should. When I render, a transparent area appears. I have this problem with my mouth switch layers as well. Can someone please take a look to see what may be wrong?
Thanks much!
You have to erase the fill and paint again. It's a problem which occurs when you paint a fill with not all the points selected.
Check this example:
if you have a shape with not all points selected
and then move the workspace until the non selected points are not visible, you will get that fill tool will "think" there is a closed shape where there isn't
I don't know if this is exactly a bug, but however you must to avoid painting when not all shape points are visible.
Post by 94253 »
That is very weird. It's fixed now; thanks for the answer! I'll be more careful in the future.
