Reseting main camera or main recording window
cookins
Post by cookins »
I was exploring something in menu and looks like I pressed something... now main camera is align on nothing and front view not seen in export movie. I can change from front view to camera only by using "View..." category in menu, because in front view with allmost far zooming - camera window not seen (like on other screen some sort), only from menu I can find it. Like on screenshots http://picasaweb.google.ru/Cookins87/Sc ... 7853409250 and http://picasaweb.google.ru/Cookins87/Sc ... 8510735986 .
how to reset camera window to where is front view located? on work place with biggest zoom and trying to locate each other - they not seen. I just need to make camera window like usual be on front side. tnx
Is "Enable 3D camera" checked in the document settings?
cookins
Post by cookins »
yes, enabled.
need to disable? what next after it?
when I disable it - front and camera view - only camera window appears and no scene....
cookins
Post by cookins »
very urgent.
Rhoel
Post by Rhoel »
Can you post the scene somewhere - this will be the fastest way of fixing it.
cookins
Post by cookins »
ok, its my first time movie on Moho...
at 0 frame - there is scene, movie begins from about 1 or 2 frame and scene is gone... what can be? (scene download from link: http://depositfiles.com/files/uhgo2mkp9)
Lost Marble
Post by Lost Marble »
Set the time to frame 0, then activate the Track Camera tool, and click "Reset" up in the tool options bar. Repeat for the Zoom Camera, Roll Camera, and Pan/Tilt Camera tools.
(It may be that only one of them got mis-aligned, but without seeing the project file I can't say for sure. Resetting them all will get you back to the original settings.)
Oops - I just read your last comment that at frame 0 or 1 the scene disappears. You may have an accidental camera keyframe at frame 1 or 2 - try deleting any camera keyframes. Other things can make the scene disappear too - it may have been dragged out of view, or turned invisible, or many other things.
muffysb
Post by muffysb »
Cookins, I'm looking at your project and I don't see any problem:
On frame 0: All of your objects are displayed.
On frame 1: There is nothing, because all of your layers are invisible.
On frame 2: The sun appears. Your other layers are invisible and positioned below the screen.
On frame 96: Your forest becomes visible and starts to move up the screen. Over time your other objects become visible as well.
So I don't have any problem viewing your scene, I assume this is how you want it to look. I have Anime Studio 6.1 so maybe there is a difference in your version, but don't think anything is wrong with your project...the problem might just be with your Anime Studio settings.
Try:
1. Choose View > Direction > Camera.
2. Press the HOME key. This brings you to the default zoom.
3. Go to frame 190. All of your objects are visible there.
Cheers,
Muffy.
cookins
Post by cookins »
vesion 6.2 resolve this.. thanks guys
cookins
Post by cookins »
when I exporting movie - just background color is visible - and no scene appears.... what it could be?>
cookins
Post by cookins »
like always - its very URGENT!
in camera view - its on scene like all ok and in front view - all ok, but in export movie just background color... :oops:
:arrow:
sbtamu
Post by sbtamu »
cookins wrote:like always - its very URGENT!
Is the background layer at top or bottom in the layers?
After drawing the shapes/lines did you hit create shape?
Double click each layer and to pull up a window and see if any are mistakenly invisible.
Sorry for bad animation
cookins
Post by cookins »
I mean background color in "project settings".
all visible - in preview feature - its like ok. in export - nothing.....
I will attach file with this scene - try exporting and have a look.
http://depositfiles.com/files/ovyjaqigc
cookins
Post by cookins »
somebody? someone? :?
gleeful
Post by gleeful »
I just looked at your .anme file. I did a preview (F5) and the background was white. I rendered one frame and the background was white.
I checked the project settings and the background was set to white.
It appears the file is working correctly.
What if?
