Corrupt file repair
Whatever...
Landolfo
Corrupt file repair
Post by Landolfo »
Hi all;
I have a divx reader with hard disk connected by a wireless network to my PC: while I was renaming some folders the network went down and the folders become files, so now are unreadable.
Now, when I connect the network drive, in the left column I have 8 folders (instead of the 10 that I had before) and two files of 0kb.
Before this problem these two files were two folders containing hundreds of files.
How can I restore them? remember that I don't have a physical access to the drive, only by network.
Thank you
__________________
spam signature removed by moderator
dueyftw
Post by dueyftw »
DO NOT SAVE ANYTHING TO THIS DRIVE, until you have run a recovery program. Most cost money but there are a few free ones. If only the link on the header of the files has been corrupted a file recovery program should work even if it is a network drive. The only thing is if you are sharing the network drive with others they might be overwriting your information.
http://www.snapfiles.com/freeware/syste ... overy.HTML
http://www.pcworld.com/downloads/collec ... files.html
There are probably more. what program will work for you? I don't know.
Dale
Moderators! Spam signature above! :!: :!:
Landolfo
Post by Landolfo »
dueyftw wrote:DO NOT SAVE ANYTHING TO THIS DRIVE, until you have run a recovery program. Most cost money but there are a few free ones. If only the link on the header of the files has been corrupted a file recovery program should work even if it is a network drive. The only thing is if you are sharing the network drive with others they might be overwriting your information.
Dale
I go to try.
Meanwhile thanks.
Bye
