Keeping Audio & Auto Lip Sync Happy-Yet-Moveable
mosscow
Post by mosscow »
I've successfully created a 5-part mouth for my character, and synced up auto dialogue for the animation. Cool. I run into a problem of moving the synced up dialogue along the timeline.
So, after I've successfully paired the two, like this:
Click for full size - Uploaded with plasq's Skitch
Now, when this happens, of course a bunch of little keyframes are generated because of this new group of movement:
Whenever I want to slide that dialogue forward or backward, I've been highlighting all the keyframes, and manually sliding them left or right. This only moves the animation, not the sound. How do I move the sound effect and the appropriate animation perfectly in sync everytime?
Thank you...
swrecordings
Post by swrecordings »
you have to move it in the sequencer
mosscow
Post by mosscow »
swrecordings wrote:you have to move it in the sequencer
Move the audio or the Mouth file? Or both, and if both, how do you select them all?
Thanks
swrecordings
you can move the audio in the sequencer and the keyframes as you did before
mosscow
Post by mosscow »
swrecordings wrote:you can move the audio in the sequencer and the keyframes as you did before
Where are the keyframes in the sequencer? All I see is the audio layer, and separately I see the Mouth folder... If I move the audio layer, then the mouth movement is out of sync?
Thank you
swrecordings
there is a tab on the timeline called "sequencer"
mosscow
Post by mosscow »
swrecordings wrote:there is a tab on the timeline called "sequencer"
Right, I guess my question was "is there a way to move the audio track in the sequencer AND the keyframes in the channel at the same time?" There isn't, isn't there? When I move one x frames, I have to move the other x frames separately. Boy, it would be a lot easier if they both just stayed in step with each other...
Thanks for your help though, SWRecordings...
Put audio and animation layer into the same group/bone layer and move just this.
mosscow
Post by mosscow »
slowtiger wrote:Put audio and animation layer into the same group/bone layer and move just this.
Ah - simple and intuitive... I thought I tried that, but I'll give it a go... Thanks SlowTiger and SWRecordings. Of course...
