When I import AVI all that comes up is a white square?
Jumproper36
Post by Jumproper36 »
I click file import movie then click the clip i want to use it shows up as a layer butjust a white square on the screen. Can Someone help? :?: :?:
swrecordings
Post by swrecordings »
you may need to convert it to another format. i have the same problem
muffysb
Post by muffysb »
Does the video appear if you export the animation? What happens if you press the "Play" button?
Jumproper36
nothing happens
when i press the play button all i see is still a white square and when i export or render it it is still just white. i also tried 3 other formats but still nothing
swrecordings
yeah, the only format that works for me is Mov.
muffysb
Post by muffysb »
Does this happen if you create a brand new project and import the video into it?
If you create a vector layer in front of the video layer, and put a black circle on the vector layer, can you see the black circle when you play/export?
Can you play the video clip in a different program on your system?
What is the size of the clip (in pixels), and what is the size of your project (in pixels)?
What operating system and version of Anime Studio are you using?
Just some questions to narrow it down.
Jumproper36
answer
wheni make a new project the same ting happens and if i do put something behind it the white square covers it up i dont know the size and i can play the video in other programs. I am using anime studio 5
muffysb
Post by muffysb »
Hmmmm, I'm a 6.1 user and I don't even have an AVI codec on my system, so I don't have any more suggestions...maybe Smith Micro technical support can help.
Good luck!
Jumproper36
thanks
i finally got it to work i converted it to the weirdest fromat i converted it to nintento WII format but it worked!!!
sbtamu
Post by sbtamu »
Have you tried to import it to Virtualdub and then saving as old avi then try to import to AS?
Also, Virtualdub is good about fixing errors that sometimes sneak into a vid. Usaually when you 1st import to Virtualdub and there is a problem you will get a message.
